The lens shows a moderate amount of barrel distortion which can be visible in critical shots especially with straight lines near the image borders. However, the distortion is symmetrical and easy to correct in post processing.
Fast lenses tend to suffer from high vignetting on full frame cameras and the AF-S 35/1.4 is no exception to this rule. In fact, with almost 2.2 EV wide open the amount of vignetting is exceptional (in a negative sense) and higher than on any other lens we've measured so far on the D3x. Such a huge amount of corner darkening is of course clearly visible in the final image. Stopping down helps to reduce vignetting, but even at f/2 the amount of light falloff remains rather high. From f/2.8 onwards vignetting is no longer field-relevant, except for really critical scenes.
In our lab tests the AF-S 35 delivers a solid performance. The center resolution is very good wide open already, increasing to excellent figures from f/2.0 onwards.
Borders and corners follow a bit behind with good resolution wide open. Stopping down helps to increase the resolution to very good figures, even toeing the line to excellent teritory around f/5.6.
The lens showed a slight amount focus shift when stopping down (residual spherical aberration).
Chromatic aberrations (color shadows at harsh contrast transitions) reach almost 2 pixels on the average at the image borders at large apertures, but decrease by stopping down. They might be visible in very large prints (or crops). However, for typical print sizes the problem isn't really field-relevant for most subjects. In addition, CAs can easily be corrected in software or by the camera itself (if you shoot JPEGs and own a current Nikon DSLR).
Bad news first - the bokeh wide open is a bit nervous. This is not only true for the transition zone, were most lenses struggle, but also for subjects at some distance from the focal plane. However, this is actually a quite typical behaviour of wide angle lenses with an aspherical element. The good news (not visible in the image below): the bokeh improves quite a bit by stopping down and becomes very smooth at f/2.8.
Thanks to 9 rounded aperture blades, background highlights retain their circular shape throughout the whole aperture range, except towards the image corners. Due to vignetting they are cut off at one side at wide open and to some degree also at f/2. There is a small amount of outlining and some traces of LoCAs (which are typical for this lens class, see next section).
notice below the halos have different colors - magenta (red + blue) in front of the focus point
Typical for most fast primes, especially ultra fast ones, the AF-S 35 shows some amount of LoCAs at large aperture settings, which can of course be reduced by stopping down.
f/1.4 |
f/2 |
f/2.8 |
f/4 |
f/5.6 |
