Nikkor AF-S 70-300mm f/4.5-5.6G ED VR (FX) - Review / Test Report - Analysis |
Nikon / Nikkor (full format)
The Nikkor shows moderate barrel distortion at 70mm switching to quite pronounced pincushion distortion at 135mm and 200mm, which is reduced to a moderate level at 300mm. The general characteristic is typical for a lens in this class, however the amount of distortion is a bit on the high side.
| 70 mm |
135 mm |
200 mm |
300 mm |
Vignetting is visibe at max. apertures but comparatively well controlled at around 1 EV. Closing the aperture by one f-stop solves most of the issue from a real-life perspective.
At its short end, the lens delivers excellent sharpness in the image center, however borders and corners show only good resolution throughout most of the aperture range. The situation is similar at 135mm, but with better border and corner sharpness, reaching very good values at f/8.
At 200mm the image center sharpness drops to very good values, with equally good borders and corners stopped down to f/8. At 300mm the center sharpness is still very good, but corners and border drop to good values.
Chromatic aberrations (color shadows at harsh contrast transitions) are rather high, ranging from around 2 to more than 3 pixels. However, please note that lateral CAs can easily be corrected in software or by the camera itself (most modern Nikon DSLRs remove CAs on-the-fly if you shoot JPGs).
