The lens shows moderate barrel distortion at around 1.1%. This is more than you'd expect from a fix focal lens. However, this is actually a typical amount of distortion for fast standard primes and unless you shoot subjects with straight lines near the image borders it's usually not field-relevant.
Typical for most fast primes, the Nikkor shows some visible vignetting wide open with a light falloff towards the corners of around 1.5 EV. As usual, stopping down reduces the corner darkening considerably. From f/2.8 onwards it's no longer an issue except for really critical subjects.
The center resolution is very good wide open already (but lacks some contrast here) and reaches excellent values at f/2.8 and beyond, except at f/11, where diffraction reduces the resolution again.
The border sharpness is very good at almost all tested apertures and excellent at f/5.6. The extreme corners follow a slight bit behind with good sharpness wide open and very good resolution at f/2.8 and beyond.
The global performance peak is reached at f/5.6.
Chromatic aberrations (color shadows at harsh contrast transitions) are moderate and in the range of roughly 1 to almost 1.4 pixels, achieving the lowest values wide open and slowly increasing with smaller apertures. This is a good result in the full format scope and not an issue in the field for most subjects. In addition, CAs can easily be corrected in software or by the camera itself (if you shoot JPEGs and own a current Nikon DSLR).
One of the primary usage scenarios for a large aperture lens is to separate the main subject from the background. In such an image the quality of the bokeh (out-of-focus blur) is of major importance.
Image blur shows traces of double contures and as such a bit nervous characteristic behind the plane of focus. Slightly stopped down (not shown here) the general impression is a bit more pleasing.
Background highlights are not perfectly circular wide open towards the borders due to mechnical vignetting. Stopped down, the shape of the aperture shapes, which are only slightly rounded, comes through and creates polygons instead of circles. The amount of outlining is quite low, though.
and green beyond.
Typical for most fast primes, the Nikkor shows noticeable bokeh fringing at large aperture settings, which can of course be reduced by stopping down.
In addition, these shots also show the focus shift when stopping down that was mentioned in the MTF section, as well as the reduced contrast wide open. The latter issue is emphasized here due to the close focus distance.
