As to be expected from a fix focal micro lens, the amount of distortion is very low at around 0.3%. Allthough measurable in the lab, this can certainly be regarded as free of distortion under field conditions.
Fast primes are expected to show visible vignetting when used at large apertures, however the amount of light falloff towards the corners at f/2.8 is surprisingly high. As usual, stopping down reduces the corner darkening considerably. From f/5.6 onwards it's no longer an issue except for really critical subjects.
The center resolution is very good wide open already and reaches excellent values at f/4 already. From f/11 onwards diffraction reduces the resolution again.
The borders and corners show very good resolution at all apertures down to f/11, the borders even reach excellent figures at f/5.6 and f/8.
Chromatic aberrations (color shadows at harsh contrast transitions) are moderate and in the range of roughly 1.7 down to 0.7 pixels, achieving the largest values wide open and slowly decreasing with smaller apertures.
CAs can easily be corrected in software or by the camera itself (if you shoot JPEGs and own a current Nikon DSLR).
The quality of the bokeh (out-of-focus blur) is generally very good, the lens shows only a slight amount of nervousness and double contures behind the focus plane.
Background highlights are not perfectly circular wide open towards the borders due to mechnical vignetting. Towards the image center they are prefectly cirular, however, and this is also true for the image boorder when slightly stopped down. Thanks to rounded aperture blades the highlights remain circular for most of the aperture range. Outlining is not an issue in highlights, however there are visible green shades due to bokeh fringing at large apertures (see next section).
and green beyond.
Typical for most fast primes, the Micro-Nikkor shows noticeable bokeh fringing at large aperture settings, which can of course be reduced by stopping down.
