Samyang 35mm f/1.4 AS UMC (Nikon FX) - Review / Test Report - Analysis
The Samyang 35mm f/1.4 shows a moderate amount of barrel distortion (~1.6%) which is usually not overly disturbing in field conditions.
In its native full format scope it produces a very heavy amount of light falloff at large aperture settings. The vignetting exceed 1.7EV (f-stops) at f/1.4 and it's still very pronounced at f/2 (1.1EV). The issue is quite well controlled at f/2.8 and not relevant anymore from f/4 onwards. This may sound like a drawback but this is actually marginally better than on the Nikkor AF-S 35mm f/1.4G.
The Samyang 35mm f/1.4 AS UMC was capable of delivering very high quality results in the MTF lab. The center is very good at f/1.4 and both the borders and corners aren't much worse either. The contrast level is slightly reduced at this setting though. There's only a slight gain in quality at f/2 but the resolution characteristic is really impressive from f/2.8 onwards. The center is pretty much outstanding between f/4 and f/8 and the outer image zone is also very good to excellent. Diffraction effects have a slight impact at f/11 but the quality is still very good here. There's only a slight amount of field curvature. The tested sample showed a slight centering defect.
Lateral CAs (color shadows) are quite low with an average pixel width of around ~0.8px at the image borders.
The quality of the bokeh (rendering of the out-of-focus blur) is, of course, a major aspect for an ultra-large aperture lens. The Samyang lens does not convince completely here. Out-of-focus highlights have a slightly nervous inner zone. The highlight shape remains pretty circular till about f/2.8 though - that's excluding the border/corner zone where the highlights suffer from the usual "cat's eyes" effect due to vignetting. The background blur is rather busy whereas the foreground blur is reasonably smooth.
Bokeh fringing is a common problem among large aperture lenses. At f/1.4 and f/2 you may be able to spot purple halos in front and green halos beyond the focus point. The issue is reduced at f/2.8 and not really visible anymore from f/4.
You may notice that the focus shift (so-called "residual spherical aberrations) is quite minimal.
f/1.4 f/2 f/2.8 f/4 f/5.6
