Sigma AF 24mm f/1.8 EX DG (FX) - Review / Test Report - Analysis
The lens shows a moderate amount of barrel distortion. This can be visible in critical shots especially with straight lines near the image borders. However, the distortion is uniform and easy to correct in post processing.
The Sigma lens shows a pronounced amount of light fall-off towards the corners. Wide open, the corners darken a lot. As usual stopping down reduces the issue, but even at rather small apertures there is still almost half a stop of vignetting left.
The lens shows very good resolution in the image center wide open, which increases to excellent levels by stopping down to f/4.
The borders and corners are a very different story, though. The borders are just fair wide open, but recover to good resolution when stopped down to f/5.6. The extreme corners are even worse wide open, but also recover to good values from f/5.6 onwards.
Chromatic aberrations (color shadows at harsh contrast transitions) are quite pronounced and range from 1.4 to well above 2 pixels at the image borders throughout the tested aperture range.
At large apertures, the EX 24 shows quite smooth bokeh in front of the focal plane, but some signs of nervousness behind it, especially in the transition zone.
Background highlights also look quite nervous and in addition show pronounced outlining. Towards the image borders, they are cut off at large aperture due to mechanical vignetting.
Both the general bokeh quality as well as background highlights improve in quality by stopping down. However, with a wide angle lens one needs to get quite close to the main subject to still get a significant amount of background blur. The lens' very short MFD comes handy here.
Bokeh fringing (non-coinciding focal planes of the various colors) is a common issue with relatively fast glass. As you can notice below, the halos have different colors - magenta (red + blue) in front the focus point and green beyond. Truly "apochromatic" lenses don't show this kind of fringing but these lenses are very rare - especially below 100mm. Unlike lateral lateral CAs, bokeh fringing cannot easily be fixed in post processing.
Typical for most fast primes, the EX 24 shows some amount of fringing at large aperture settings, which can of course be reduced by stopping down.
f/1.8 f/2.8 f/4.0 f/5.6 f/8.0
