The lens shows a small amount of less than 1% barrel distortion, which is rather low for this kind of lens.
Very fast lenses usually suffer from pronounced vignetting at large apertures, and the Sigma is no exception to this rule. Wide open, there is a significant amount of light fall-off towards the borders. As usual, stopping down reduces the amount of vignetting considerably. At f/2.8, vignetting is already down to moderate levels and from f/4 onwards it should no longer be an issue for most subjects.
The lens delivers impressive resolution in our lab test. In the image center, the results are very good at the largest aperture, and increases to excellent values from f/2 onwards. At f/11 (and beyond), diffraction limits the maximum resolution again.
The borders and corners also perform on a very high level. At medium aperture settings (f/4 and f/5.6) the border even reach excellent values, too.
It is worth mentioning that the lens showed no focus shift when stopping down (residual spherical aberration).
Chromatic aberrations (color shadows at harsh contrast transitions) are well controlled and show only moderate values of below 1 pixel at the image borders.
The lens generally delivers quite smooth bokeh, especially for a wide angle prime. In our test scene below the Sigma shows a tad of nervousness in the transition zone. During our field tests we noticed this also at medium aperture settings with subjects in the distant background (see the sample images on the next page).
Thanks to 9 rounded aperture blades, background highlights retain their circular shape throughout the whole aperture range, except towards the image corners, where they are cut off a little at one side due to mechanical vignetting. There is almost no outlining in the disks formed by highlights, in fact the blur is evenly distributed.
notice below the halos have different colors - magenta (red + blue) in front of the focus point
Typical for most fast primes, especially ultra fast ones, the Sigma shows some amount of bokeh fringing at large aperture settings, which can of course be reduced by stopping down.
In addition, these shots also illustrate that there is no focus shift when stopping down, as it was already mentioned in the MTF section.
f/1.4 |
f/2 |
f/2.8 |
f/4 |
f/5.6 |
