Tokina AF 100mm f/2.8 AT-X Pro D macro (FX) - Review / Test Report - Analysis
Basically none. Even though Imatest still sees tiny traces of barrel distortion (0.06%), this practically means: zero.
With just 2/3 stops wide open, light fall-off towards the corners is surprisingly low for such a lens. As usual, stopping down reduces the amount of vignetting to even lower numbers.
In the image center, the lens shows very good resolution wide open, increasing to excellent levels at medium aperture settings.
The image borders are very good wide open, too, but don't profit that much from stopping down. The extreme corners are one step softer wide open, but almost catch up to the borders from f/4 and beyond.
The lens showed no focus shift when stopping down (no residual spherical aberration).
Chromatic aberrations (color shadows at harsh contrast transitions) are well controlled at large apertures, increasing to values around 1 pixel on average at the image borders by stopping down to f/5.6 and beyond.
Thze lens produces very smooth image blur in front of the focal plane. In the transition zone and behind the focal plane, bokeh is a little less smooth though.
Even though the Tokina does not feature rounded aperture blades, background highlights have an almost circular shape even when stopped down thanks to 9 blades in total. There is a small amount of outlining and, more pronounced, quite some bokeh fringing at highlight borders (see also next section).
The Tokina shows a fair amount of bokeh fringing wide open, which as usual decreases by stopping down.
As mentioned in the MTF section already, these shots also illustrate that there is no focus shift by stopping down.
f/2.8 f/4.0 f/5.6 f/8.0 f/11.0
