Sigma AF 24mm f/1.4 DG HSM | A ("Art") (Nikon FX) - Review / Test Report - Analysis |
Nikon / Nikkor (full format)
The lens produces a small amount of barrel distortion (0.9%), which is better than most in this class.
Very fast and wide lenses tend to suffer from pronounced vignetting at large apertures and the Sigma has its share of problems here. Wide open, there is a very hefty amount of light falloff (>2.4EV). As usual, stopping down reduces the amount of vignetting considerably. At f/2.8, the vignetting is already down to very moderate levels and from f/4 onward it should no longer be an issue for most scenes.
The Sigma delivers excellent resoultion in the image center straight from the maximum aperture.
The borders and extreme corners struggle at large aperture settings, but stopped down to f/2.8 and beyond deliver good resolution, too.
Chromatic aberrations (color shadows at harsh contrast transitions) are well controlled, on average showing readings of below 1px at the image borders.
Wide-angle lenses, especially those with many aspherical elements, are not the best performers in this category but the Sigma is way above average here (in this class). In our test scene below the Sigma shows a bit of nervousness in the focus transition zones but we've seen much worse here really. However, it should be mentioned that there is some smearing at the image borders/corners.
A surprising finding is that out-of-focus highlights are rendered quite beautifully with a comparatively smooth inner zone and only slight outlining of the highlight discs. As usual you will have to live with a deterioration of the disc shape towards the image borders at large apertures - this is a vignetting effect and pretty much unavoidable on full format cameras.
Bokeh fringing (non-coinciding focal planes of the various colors) is a common issue with relatively fast glass. As you can notice below the halos have different colors - magenta (red + blue) in front of the focus point and green beyond. Unlike lateral lateral CAs, bokeh fringing can not easily be fixed in post processing.
Typical for most ultra fast primes the Sigma shows a certain amount of bokeh fringing at large aperture settings but the result is above average here again. The fringing can be reduced by stopping down and it's mostly gone from f/2.8 onward.
In addition, these shots also illustrate that there is virtually no focus shift when stopping down.
f/1.4 |
f/2 |
f/2.8 |
f/4 |
