The tiny pancake lens produces a slight degree of barrel distortion (~0.85%) which is rarely noticeable in field conditions (fig. 1). However, keep in mind that Micro-4/3 images are auto-corrected according to the stored lens profile, which is done either by the camera directly (JPEG) or by the more popular RAW-converters a la Photoshop. The second figure shows the original RAW results and thus the principal capability of the lens with a very heavy barrel distortion of ~5% which is actually very extreme for a prime lens.
- Figure 1 - Auto-corrected image
- Figure 2 - RAW converted via RAW Therapee
The following graph shows the vignetting characteristic of the Panasonic Lumix G 14mm f/2.5 ASPH between open aperture and f/8.0.
The wide-angle lens has a fairly mediocre vignetting characteristic and it is not automatically corrected. The figure below shows the corresponding performance of JPEGs obtained straight from the camera. At f/2.5 the amount of vignetting is around ~1.2EV which is heavy as well as easily noticeable in field images and the the situation improves significantly when stopping down to f/4.0 and it's not really an issue anymore from f/5.6 onwards.
- Figure 3 - Vignetting at f/2.5, 4.0, 5.6 and 8.0
The prime lens disappoints somewhat regarding its resolution capabilities. The center quality is generally on a very good to excellent level throughout the relevant aperture range. However, the borders/corners are good to very good. However, apart from f/2.5 - with slightly softer extreme corners - the border as well as extreme corners show surprisingly constant values with only slight deviations.
Lateral CAs (color shadows at harsh contrast transitions) are very well controlled reaching a maximum of less than 0.2px at the image borders, which isn't really field relevant anymore.
However, we need to mention again that this is the result of the usual auto-correction applied by the camera (or Photoshop). The "RAW" CAs are as pronounced as 0,9px which is still pretty good in absolute terms albeit a little strong for a prime lens.
