Panasonic LUMIX G VARIO 100-300mm f/4-5.6 MEGA O.I.S. - Review / Test Report - Analysis
Typical for most tele zoom lenses the Panasonic produces a low level of distortion. The lens shows slight pincushion distortion (~1%) at 100mm changing to slight barrel distortion at 300mm (~0.3%). This is nothing to worry about in field conditions.
The super telephoto lens has an average vignetting characteristic. The following figures show the corresponding performance of auto-corrected JPEGs obtained straight from the camera compared to non-corrected raw files.
The focal length between 100 and 200mm shows only slight vignetting. However, at 300mm and wide open aperture the amount of vignetting is very pronounced at ~0,9EV which is easily noticeable in field images. Nevertheless, vignetting it's not really an issue anymore from f/8 onwards. The non-corrected (RAW) images show slightly worse results particularly at 300mm with a heavy amount of vignetting of up to ~1.2EV at f/5.6.
The following graphs compare the vignetting characteristic of auto- and non-corrected files between 100 and 300mm from open aperture to f/11.
Vignettingat 100mm (corrected)at 100mmf/4-4.9f/5.6f/8f110.0EV0.3EV0.6EV0.9EV1.2EV1.5EVEV (f-stops) opticallimits.com
Vignettingat 200mm (corrected)at 200mmf/4-4.9f/5.6f/8f110.0EV0.3EV0.6EV0.9EV1.2EV1.5EVEV (f-stops) opticallimits.com
Vignettingat 300mm (corrected)at 300mmf/4-4.9f/5.6f/8f110.0EV0.3EV0.6EV0.9EV1.2EV1.5EVEV (f-stops) opticallimits.com
The following images illustrate the above mentioned heavy vignetting at 300mm.
The Panasonic lens produced decent but not stellar resolution figures in the MTF lab although this is certainly acceptable considering its huge focal length range. The performance is best at 100mm with a generally good to very good quality across the image field. There's a slight decrease in performance towards 200mm and slightly more so at 300mm.
MTFat 100mmcenterborderextremef/4f/5.6f/8f119001,2301,5601,8902,2202,550LW/PH opticallimits.com
MTFat 200mmcenterborderextremef/4.9f/5.6f/8f119001,2301,5601,8902,2202,550LW/PH opticallimits.com
MTFat 300mmcenterborderextremef/5.6f/8f119001,2301,5601,8902,2202,550LW/PH opticallimits.com
A good news for Panasonic users is the low amount of lateral CAs (color shadows at harsh contrast transitions) - at least when shooting JPEGs or using mainstream RAW converters. These color shadows are negligible throughout the whole focal length with an average CA width of around ~0.4px at the image borders.
However, the non-corrected RAWS show a completely different situation with an average CA width of around ~1.2px at 200mm and almost 2px at 300mm. These values can be very disturbing on Olympus cameras where the RAWs are not auto-corrected in this respect.
Lateral CAsat 100mmCA px width (corrected)CA px widthf/4-4.9f/5.6f/8f110.0px0.4px0.8px1.2px1.6px2.0px2.4px2.8pxaverage pixel width (border) opticallimits.com
Lateral CAsat 200mmCA px width (corrected)CA px widthf/4-4.9f/5.6f/8f110.0px0.4px0.8px1.2px1.6px2.0px2.4px2.8pxaverage pixel width (border) opticallimits.com
Lateral CAsat 300mmCA px width (corrected)CA px widthf/4-4.9f/5.6f/8f110.0px0.4px0.8px1.2px1.6px2.0px2.4px2.8pxaverage pixel width (border) opticallimits.com
