Pentax SMC-DA 21mm f/3.2 AL Limited - Review / Test Report - Analysis
The DA 21mm f/3.2 produces a relatively pronounced degree of barrel distortion (~2%) - this is not dramatic but a bit higher than expected/desirable for a newly designed fix-focal lens.
The DA 21mm f/3.2 is a dedicated APS-C lens and as such it tends to produce a comparatively higher degree of vignetting. At f/3.2 the problem is indeed more pronounced at 1.04EV. That's not too bad for a 21mm lens although not stellar either. The situation is already much better by f/4 and no longer field relevant by f/5.6.
The DA 21mm f/3.2 Limited produced very good although not superb resolution results in the MTF lab. The center performance is already exceptionally high straight from f/3.2 whereas the border quality isn't quite as high. At f/3.2-f/4 the borders show good results but the real boost towards very good quality occurs at f/5.6-f/8. At f/11 there's a general decrease in quality due to the usual diffraction effects.
Please note that the difference between f/3.2 and f/4 is only a 2/3 aperture so the gain in quality isn't overly pronounced between these two settings.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are fairly well controlled for a lens in this focal length class. The average CA pixel width at the image borders stays at and below 0.9px - this may be visible here and there but usually not to an annoying degree.
(Note: CAs can be reduced via imaging tools)
