Pentax SMC-FA 31mm f/1.8 AL Limited - Review / Test Report |
The Pentax SMC FA 31mm f/1.8 AL Limited is the most pronounced wide angle
of classic FA Limited lenses. Similar to its cousins it offers an
absolutely superb build quality ... at a price (900-1000€/US$).
However, to be fair the ultra-large aperture (for a wide-angle
lens) is also off the mainstream and quality simply doesn't come for free.
Typical for all FA lenses it supports the full 35mm format so it can be
used both on film and digital SLRs. On the Pentax K10D its field-of-view
is equivalent to about 47mm (full format) so within this scope the lens
gets transformed to a "normal" lens.
The build quality of the lens is exceptional with all parts made of metal.
The small focus ring operates very smooth and slightly damped. Typical
for FA-type lenses there's still a dedicated aperture ring on the lens.
The FA 31mm f/1.8 extends a little when focusing towards close distances.
Pentax also implemented a built-in flower shaped hood which cannot be removed
nor would this be desirable regarding its small size.
The lens is/was available both in a silver- and black-colored variant.
Unlike its cousins it isn't really a small nor overly light-weight lens.
The FA 31mm f/1.8 has no internal AF motor and relies on a slotted drive screw operated
by the camera. As a result AF operation will generate a moderate degree of noise.
The AF speed is very fast on the K10D.
| Equiv. focal length | 47 mm (full format equivalent) |
| Equiv. aperture | f/2.7 (full format equivalent, in terms of depth-of-field) |
| Optical construction | 9 elements in 7 groups inc. 1 aspherical, 1 ED and 1 HRLD element |
| min. focus distance | 0.3 m (max. magnification ratio 1:6.25) |
| Dimensions | 65 x 69 mm |
| Weight | 345 g |
| Filter size | 58 mm (non-rotating) |
| Hood | built-in, flower-shaped |
| Other features | - |
