Pentax SMC-FA 35mm f/2 AL - Review / Test Report - Analysis
The FA 35mm f/2 AL exhibits only a minor degree of barrel distortion (~0.85%) - this is usually nothing to worry about in field conditions.
As a full format lens the FA 35mm f/2 benefits from the usual sweet spot effect on APS-C DSLRs. At f/2 the level of vignetting is already fairly moderate (0.66EV) and negligible from f/2.8 onwards.
The first tested sample of the lens had a centering defect which spoiled the results quite a bit. However, a re-test with a 2nd sample showed the full potential of the lens. At f/2 the lens is already capable to deliver a very good performance across the frame. Stopping down increases the resolution even further till an outstanding maximum is reached around f/4. At f/8 there're marginal diffraction effects but the quality remains easily on an excellent level.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are very low at f/2 and the problem does only increase slightly towards smaller apertures. Even at its peak (f/8) the CAs are only on a medium level with an average width of ~1.2px at the image borders.
Typical for many ultra-large aperture lenses you can experience some purple fringing in extreme contrast conditions at wide-open aperture. Here's an example (100% border crop of a water fountain image):
