Pentax SMC-DA 40mm f/2.8 Limited - Review / Test Report - Analysis
Typical for standard/normal lenses the Pentax DA 40mm exhibits only a minor degree of barrel distortion (~0.6%) - nothing to worry about under field conditions.
Regarding its APS-C image circle it doesn't really surprise that the DA 40mm f/2.8 produces a some vignetting at wide-open aperture (0.9EV). At f/4 the problem is already greatly reduced and it's negligible from f/4 onwards.
Pancake lenses have the reputation to produce a very even resolution across the frame but at cost of peak performance. The Pentax DA 40mm f/2.8 Limited is indeed not as sharp as its direct cousins but frankly the difference is not really detectable by the naked eye. In the lab the lens was a already able to deliver very good results at f/2.8 and an excellent quality between f/4 and f/8. Typical for all lenses diffraction reduces the quality from f/11 onwards. The sweet spot is at f/5.6.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are a non-issue of the Pentax. A rare but very welcome characteristic.
