Pentax SMC-FA 43mm f/1.9 Limited - Review / Test Report
Review by Klaus Schroiff, published April 2007
The Pentax SMC FA 43mm f/1.9 is another "Limited" lenses made by Pentax. At around 550€/US$ it is certainly not a budget item especially for a "normal" lens but in a swamp of budget oriented plastic lenses the high quality Pentax lens makes a welcome difference. Typical for all FA lenses it supports the full 35mm format so it can be used both on film and digital SLRs. On the Pentax K10D its field-of-view is equivalent to 64.5mm so it leaves its original scope as a "normal" lens towards a very moderate tele.
The build quality of the lens is superb with most parts made of metal. The tiny focus ring operates very smooth and slightly damped. Typical for FA-type lenses there's a dedicated aperture ring on the lens. The lens is/was available in a platinum- and black-colored variant. As you have surely noticed the platinum version looks a little alien on the K10D.
The lens has no internal AF motor and relies on a slotted drive screw operated by the camera. As a result AF operation will generate a moderate degree of noise. The AF speed is very fast on the K10D.
Equiv. focal length64.5 mm (full format equivalent)
Equiv. aperturef/2.9 (full format equivalent, in terms of depth-of-field)
Optical construction7 elements in 6 groups
Number of aperture blades8
min. focus distance0.45 m (max. magnification ratio 1:8)
Dimensions64 x 24 mm
Weight155 g
Hoodsnap-on type (supplied)
Other features-
