Zeiss Vario-Sonnar T* 24-70mm f/2.8 ZA SSM (Sony SAL-2470Z) - APS-C Review / Test Report - Analysis
The Zeiss has a typical 3x zoom ratio and in combination with its full format character it shows only a very moderate amount of distortion within the APS-C scope. Unsurprisingly it is most pronounced at 24mm (1.6% barrel distortion) whereas the problem is basically negligible at 40mm and 70mm.
24mm 40mm 70mm
Thanks to the full format design the amount of vignetting is not field-relevant even at max. aperture.
The Zeiss produced superb resolution figures in the MTF lab. The center resolution resides at and sometimes probably even beyond the limits of the 12mp sensor of the Alpha 700 at all tested apertures and throughout the zoom range. The border resolution is only slightly worse at 24mm and it improves towards 40mm. At 70mm there's a more pronounced drop in border quality although there's still no real reason to complain here ... technically that is. The bad news is that both tested samples suffered from a more or less visible centering problem at 70mm which had surely a certain influence here. Naturally 2 samples are not statistically relevant to reveal a pattern here but this shouldn't happen in this price league.
Field curvature is pretty much a non-issue with this lens - this is a significant problem of its Nikon counterpart.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are generally quite well controlled. You may still be able to notice some CAs in field images when using a wide-angle setting (~1.1px). The problem eases when zooming towards the long end of the range.
Needless to say but you can correct or at least reduce lateral CAs during post-processing e.g. via Photoshop.
Bokeh (out of focus blur)
The quality of the bokeh is not a strength of the Zeiss lens - at least not at 70mm but this is surely the most interesting spot to look for. The out-of-focus hightlights show a rather pronounced outlining effect and hard contrast edges can produce halos rather than a soft fading. This is somewhat disappointing.
Here're some 100% sample crops illustrating the problem:
