Sony 50mm f/2.8 macro ( SAL-50M28 ) - Review / Test Report - Analysis
Typical for all macro lenses the Sony 50mm f/2.8 macro produces images which are basically free of distortion (~0.18%).
The Sony 50mm f/2.8 macro is a full format lens and as such enjoying the usual sweet spot advantage when used on an APS-C DSLR. Within this scope the lens shows moderate vignetting at f/2.8 (0.65EV) and the problem is pretty much negligible from f/4 onwards.
The Sony 50mm f/2.8 macro produced very good to excellent resolution figures in the MTF lab. At f/2.8 you can expect an excellent center quality and very good borders. The performance peak is reached around f/5.6 with an excellent resolution across the frame. The quality is still very acceptable at f/16 but you should avoid smaller apertures beyond due to diffraction effects.
Lateral chromatic aberrations (color shadows at harsh contrast transitions) are fairly high for a fix-focal lens with an average pixel width between 1.3px and 0.7px at the image borders. However, this is still moderate from a global perspective and usually no problem in field conditions.
The quality of the bokeh is a primary playground for a macro lens and the Sony lens is capable of producing very decent results here. The rounded aperture shape in out-of-focus highlights remains intact at f/2.8 and f/4 but circular shapes are somewhat distorted towards ellipsoids near the image borders. The blur is very smooth and uniform.
LoCAs (non-coinciding focal planes of the various colors), sometimes called "bokeh CAs", may be visible in very critical scenes at f/2.8. As you can notice below the halos have different colors - magenta (red + blue) in front the focus point and green beyond. It's not a real issue anymore from f/4 onwards.
f/2.8 f/4
