Make
SONY
Model
NEX-5
ISO Speed
200
Focal Length
16.0mm
Aperture:
f/2.8
Exposure
1/3200s
Make
SONY
Model
NEX-5
ISO Speed
200
Focal Length
16.0mm
Aperture:
f/9.0
Exposure
1/400s
Make
SONY
Model
NEX-5
ISO Speed
800
Focal Length
16.0mm
Aperture:
f/4.0
Exposure
1/125s
Make
SONY
Model
NEX-5
ISO Speed
200
Focal Length
16.0mm
Aperture:
f/9.0
Exposure
1/400s
Make
SONY
Model
NEX-5
ISO Speed
200
Focal Length
16.0mm
Aperture:
f/5.0
Exposure
1/250s
Make
SONY
Model
NEX-5
ISO Speed
200
Focal Length
16.0mm
Aperture:
f/9.0
Exposure
1/800s
Make
SONY
Model
NEX-5
ISO Speed
200
Focal Length
16.0mm
Aperture:
f/9.0
Exposure
1/320s
Make
SONY
Model
NEX-5
ISO Speed
200
Focal Length
16.0mm
Aperture:
f/9.0
Exposure
1/320s
Make
SONY
Model
NEX-5
ISO Speed
200
Focal Length
16.0mm
Aperture:
f/9.0
Exposure
1/250s
Make
SONY
Model
NEX-5
ISO Speed
200
Focal Length
16.0mm
Aperture:
f/2.8
Exposure
1/4000s
Make
SONY
Model
NEX-5
ISO Speed
200
Focal Length
16.0mm
Aperture:
f/9.0
Exposure
1/500s
Make
SONY
Model
NEX-5
ISO Speed
200
Focal Length
16.0mm
Aperture:
f/9.0
Exposure
1/640s
The Sony E 16mm f/2.8 is a controversial lens. Upon first contact you're probably positively surprised - it's stylish, dwarfish,
very well built and the AF performance is also pretty good. It doesn't even cost a fortune. Unfortunately that's
where most of the glory ends. The lens delivers very sharp images in the inner image field but the corner performance
is rather poor especially at f/2.8 and f/4. The fairly heavy amount of lateral CAs isn't helpful here either. However, to be
fair - if you use the lens at f/8, the sweet spot, it is actually capable of delivering good results across the image field and the corners are usually not all that important when taking images at f/2.8 anyway. The bokeh (quality of the out-of-focus blur) can be quite rough in critical scenes although that's typical for most wide-angle lenses. The amount of vignetting is class-average at f/2.8 but it could be somewhat lower at smaller apertures - this applies to auto-corrected vignetting. The native vignetting is much higher! Distortions are well controlled and not overly relevant from a field perspective. So technically it isn't really an impressive lens but it can give you quite good results if you're aware of its limitations and maneuver around them.
