Sony E 18-55mm f/3.5-5.6 OSS (Sony NEX) - Review / Lens Test Report - Analysis
The 18-55mm OSS exhibits a fairly hefty amount of barrel distortion at 18mm (~4%). There is basically no distortion at 24mm but the characteristic turns to moderate (~2.1%) pincushion distortion at 35mm and slight (~1%) pincushion distortion at 55mm.
18mm 24mm 35mm 55mm
The vignetting characteristic is a bit on the odd side. There's a basically constant amount of light fall-off at 18mm. This is highly unusual so we suspect an automated vignetting compensation "under the hood" (inc. RAW). At around ~0.7 f-stops the problem may be just noticeable in critical scenes but it's usually nothing to worry about at such a wide setting. Vignetting is a non-issue from 24mm onwards.
Update: It is, by now, obvious that these figures show the results with vignetting auto-compensation!
The Sony lens produced decent resolution figures in the MTF lab. The center resolution is generally excellent till f/8 and the border quality varies around the good-to-very good (just) barrier - this characteristic is kept across the focal length range although there's a slight dampening at 55mm. Diffraction effects start to have a stronger negative effect beyond f/8. The centering quality of the tested lens wasn't great.
Lateral CAs (color shadows at harsh contrast transitions) are a weak spot of the Sony lens. The issue is very pronounced at 18mm and 35mm at medium aperture settings and easily visible in images. Interestingly lateral CAs are not much of an issue at 24mm and 55mm.
