Leica Summarit-M 50mm f/2.5 on Sony NEX - Review / Lens Test Report - Sample Images & Verdict |
Here're some RAW-converted images taken with the NEX-5. Please note that there's no valid EXIF data due to the lack of electronic coupling. Most images were either taken at f/2.5 or f/8 so you may roughly conclude the aperture settings from the depth-of-field.
Make |
SONY |
Model |
NEX-5 |
ISO Speed |
200 |
Focal Length |
Aperture: |
f/1.0 |
Exposure |
1/4000s |
Make |
SONY |
Model |
NEX-5 |
ISO Speed |
200 |
Focal Length |
Aperture: |
f/1.0 |
Exposure |
1/800s |
Make |
SONY |
Model |
NEX-5 |
ISO Speed |
200 |
Focal Length |
Aperture: |
f/1.0 |
Exposure |
1/160s |
Make |
SONY |
Model |
NEX-5 |
ISO Speed |
200 |
Focal Length |
Aperture: |
f/1.0 |
Exposure |
1/1000s |
Make |
SONY |
Model |
NEX-5 |
ISO Speed |
200 |
Focal Length |
Aperture: |
f/1.0 |
Exposure |
1/4000s |
Make |
SONY |
Model |
NEX-5 |
ISO Speed |
200 |
Focal Length |
Aperture: |
f/1.0 |
Exposure |
1/640s |
VerdictThe Leica Summarit-M 50mm f/2.5 is a lens for enthusiasts. Its execution is next to perfect and you can feel that it was made with passion rather than task-work and that's despite the rather "low" price tag for a Leica lens. However, even an low-priced Leica lens is hardly meant for the masses so you've to pay dearly for the privilege. In optical terms it is certainly an impressive lens and a tad better than the Zeiss ZM Planar 50mm f/2 that we've tested here recently. The Summarit is already perfectly usable at f/2.5 and the results are very sharp from f/4 onwards. Lateral CAs are mostly well-controlled. Vignetting is basically a non-issue on the Sony NEX. Distortions are non-existent. The quality of the bokeh is smooth and buttery although it suffers a little from the comparatively slow max. aperture. The lens has a bit of a focus shift when stopping down - possibly the biggest "weakness" of the lens. The Sony NEX-Leica combination is absolutely beautiful but you'll probably rarely see it out there. Leica lenses are already quite exotic and most will use them on the Leica M8/9 anyway. However, if you're looking for the best 50mm lens for your Sony camera - this may well be it.
