Voigtlander Heliar 50mm f/3.5 (on Sony NEX) - Review / Test Report - Analysis |
The Voigtländer lens produces a low amount of barrel distortion (~0.7%) which is usually not relevant in field conditions.
Typical for full format lenses it has no real issues with respect to light fall-off on an APS-C camera. At max. aperture the vignetting is barely something worry about in real world situations (@ 0.5EV) and it's absolutely negligible from f/5.6 onwards.
The Heliar delivers a fairly impressive resolution across the tested aperture range although we wouldn't really confirm that it is really the "sharpest 50mm lens ever made". The center quality is already excellent at f/3.5 and the borders follow on a good level here. The borders receive a boost towards very good quality at f/5.6 which is also the sweet spot of the lens on the Sony NEX. Diffraction effects reduce the quality from f/11 onwards.
Lateral CAs are very well controlled with an average pixel width at around 1px at the image borders. This isn't really objectionable in field conditions.
The Heliar 50mm f/3.5 is a fairly slow lens so it's relatively hard to produce a pronounced out-of-focus blur (go close). Out-of-focus highlights have a slightly nervous rendition and the discs aren't really circular towards the (APS-C) image corners. The quality of the blur in the critical focus transition zones is pretty smooth in the foreground, somewhat less so in the image background.
notice below the halos have different colors - magenta (red + blue) in front the focus point and green beyond. Regarding the slow speed of the lens it is really only a small issue at f/3.5 (bokeh fringing does primarily occur at and below f/2.8).
