Sony 70-200mm f/2.8 SSM G (SAL-70200G) - Full Format Review / Lab Test |
Review by Klaus Schroiff, published December 2010
Lens kindly provided by Dieter Scherk!
The Sony 70-200mm f/2.8 SSM G is part of Sony professional Gold lineup.
It is actually the last of the Mohican - it was designed during the very last phase
of the Minolta era and its current incarnation is "only" a relabeled and restyled
variant. There's, of course, nothing bad about this. We tested the lens a while
ago on an APS-C DSLR but let's have a look how it performs within its native full format.
The build quality of the lens is exceptional. The lens body is obviously
made of metal and both the focus and zoom control rings feel tight and
smooth to handle. Typical for most Sony lenses the fluted rubber
rings offer lots of grip but they have an inevitable tendency to collect
dust in no time.
The physical length remains constant regardless of the zoom or focus setting.
The front element does not rotate thanks to the internal focusing (IF) system.
The lens does not feature any sealing against dust and humidity which is somewhat
unfortunate regarding the (professional) target audience as well as relative
to competing lenses by Canon or Nikon.
The petal-shaped lens hood has an interesting feature: you can remove a
little window cover which provides access to the filter thread - this
is highly useful if you intend to use a polarizer.
Another interesting aspect of the lens is the SSM - the SuperSonic AF
Motor which is similar to Canon's USM or Nikon's SWM. It is fast (although not as
fast as in the Zeiss ZA 24-70mm f/2.8 for instance), near silent and very accurate. Sony did also
incorporate 3 focus-lock buttons plus a dedicated AF/MF switch as well as a focus limiter.
| Optical construction | 19 elements in 16 groups inc. 4x ED elements |
| min. focus distance | 1.2 m (max. magnification ratio 1:5) |
| Dimensions | 87 x 197 mm |
| Weight | 1340 g (without tripod mount) |
| Hood | petal-shaped (metal), snap-on, supplied |
| Other features | DMF, 3 focus-stop buttons, focus limiter |
