Nikkor AF 20mm f/2.8 D (FX) - Review / Test Report - Analysis |
Nikon / Nikkor (full format)
Typical for most wide angle lenses the lens produces visible barrel distortion with a little mustache sub-style.
The Nikkor shows very pronounced light falloff towards the image corners, wide open and at f/4. Even stopped down to f/5.6 the lens still shows vignetting of almost 1 EV. From f/8 onwards, the amount of corner darkening is probably not an issue anymore for most subjects, but it still remains on a rather high level for such aperture values. In summary, this is quite poor performance in this regard, but most likely a tribute to the lens' quite compact design.
In the image center the lens shows very good resolution wide open already, reaching excellent sharpness from f/4 onwards (until diffraction limits the maximum achievable resolution at f/11 and beyond).
The image borders and corners are about one school mark behinde. Wide open, the sharpness is good, stopped down to f/5.6 and beyond both borders and corners show very good resolution.
Chromatic aberrations (color shadows at harsh contrast transitions) are quite pronounced and in the range of roughly 1.9 to 2.4 pixels throughout the tested apertures. However, CAs can easily be corrected in software or by the camera itself (if you shoot JPEGs and own a current Nikon DSLR).
