The lens shows moderate barrel distortion at the short end, switching over to a small amount pincushion distortion at the opposite end of the zoom range. At medium focal lenght settings, the lens is practically free of distortion.
80mm |
135mm |
200mm |
Typical for a fast zoom lens, the amount of vignetting is somewhat pronounced at the largest aperture setting, but stopping down reduces the border light fall-off to usually irrelevant levels.
At all focal length settings the image center delivers very good resolution wide open, which increases to excellent sharpness when stopped down.
At 80 mm the borders and corners are generally very good at all tested aperture settings. Towards longer focal lengths, the quality drops a little here at large apertures, but stopped down to f/5.6 or f/8 the borders and corners still reach very good resolution.
Chromatic aberrations (color shadows at harsh contrast transitions) are somewhat pronounced with up to almost 2 pixels at the image borders at 80mm, but reduce to lower levels at longer focal lengths.
Please note that lateral CAs can easily be corrected in software or by the camera itself (most modern Nikon DSLRs remove CAs on-the-fly if you shoot JPGs).
Being a fast tele lens one of the lens' welcome abilities is to separate the main subject from the background, so rendering of out of focus areas is an important aspect.
The AF-S 80-200 delivers a generally very smooth bokeh at all focal lengths.
Thanks to 9 rounded aperture blades, background highlights remain circular throughout the whole aperture and focal range, except at the image borders where they are cut off due to mechanical vignetting. They show a smooth filling with almost no outlining.
Bokeh fringing (non-coinciding focal planes of the various colors) is a common issue with relatively fast glass. As you can
and green beyond. Truly "apochromatic" lenses don't show this kind of fringing but these lenses are very rare. Unlike lateral lateral CAs, bokeh fringing cannot easily be fixed in post processing.
At its longest focal length of 200 mm (which we used for the shots below) the lens shows a moderate amount of LoCAs wide open, which is considerably reduced by f/4 already and no longer field-relevant at f/5.6 and beyond.
