					Nikkor AF 24mm f/2.8 D (FX) - Review / Test Report - Analysis			 |
						Lens Reviews											 -
						Nikon / Nikkor (full format)
The lens shows moderate barrel distortion at around 1.8% with a little mustache sub-style.
The Nikkor shows very pronounced light falloff towards the image corners wide open and also at f/4. Stopped down to f/5.6 and beyond vignetting is reduced to a level that is no longer an issue for most subjects.
In the image center the lens shows very good resolution wide open and at f/4, reaching excellent sharpness from f/5.6 onwards (until diffraction limits the maximum achievable resolution at f/11 and beyond).
The image borders and corners are rather soft wide open, but stopping help to raise the sharpness to good values at f/4 and very good resolution at f/5.6 and beyond. The performance peak of the lens is reached at f/8.
Chromatic aberrations (color shadows at harsh contrast transitions) are moderate at large apertures, but increase considerably by stopping down. However, CAs can easily be corrected in software or by the camera itself (if you shoot JPEGs and own a current Nikon DSLR).
A 24mm prime is certainly not primarily designed to throw the background out of focus (to the contrary, actually). However, with its ability to focus rather close combined with the large aperture the lens is able to separate the main subject from the background (at least for larger subject-to-background distances). So, let's have a quick look at the bokeh quality.
Out of focus areas show some nervousness and doubled contures. Background highlights are quite distorted towards the image borders at f/2.8 and f/4, but circular at f/5.6. Quite strong outlining increases the overall unpleasant character of the lens' bokeh.
