No surprises here: the lens shows almost no distortion, but anything else would have been a major disappointment for a macro prime.
The light fall-off towards the image borders is a little pronounced at the largest aperture setting, reaching a value of almost 1.4 stops here. As usual, stopping down resolves the issue. From f/5.6 onwards vignetting should no longer be a visible issue for most subjects.
The lens delivers very good resolution in the image center at the maximum aperture, increasing to excellent values stopped down to medium apertures.
Borders and corners follow a bit behind with very good resolution throughout most of the tested aperture range. Stopped down to medium aperture settings, the borders even manage to reach excellent sharpness, too.
From f/11 onwards, diffraction starts to take its toll and reduces the achievable resolution. The lens can be stopped down to f/32, but at this setting not much resolution is left. This is a physical limitation and not a design flaw of the lens.
It's worth to mention that the lens showed no focus shift when stopping down.
Chromatic aberrations (color shadows at harsh contrast transitions) range from 1 to almost 1.5 pixels on the image borders, slowly increasing by stopping down.
The lens produces quite smooth background blur wide open, even in the sometimes critical transition zone.
Thanks to rounded aperture blades, background highlights show a nice circular shape... as long as they are not too far away from the image center. Towards the image corners, highlights are cut off due to mechanical vignetting, even when slightly stopped down. This is probably due to the rather small diameter of the front lens.
Apart from the cut-off, highlights are evenly filled and show almost no outlining. However, there is a visible degree of bokeh fringing at the borders (see next section).
and green beyond.
Typical for most primes in this class, the Nikkor shows a noticeable amount of bokeh fringing at large aperture settings, which can of course be reduced by stopping down.
As mentioned earlier, these shots also illustrate that there is no focus shift by stopping down.
