Voigtlander Color Heliar 75mm f/2.5 (on Sony NEX) - Review / Test Report - Analysis |
The Color Heliar produces a slight amount of pincushion distortion (~0.7%) which is not overly field relevant.
Typical for full format lenses it has a walk-over on APS-C cameras with respect to light fall-off. The issue is pretty much negligible straight from f/2.5 onwards.
The Voigtlander lens delivers very decent resolution characteristics across the tested aperture range but it's not bitingly sharp. The center quality is very good at f/2.5 and the borders follow on a good level here so it is perfectly usable here. The border quality increases till it reaches a very good maximum at f/5.6. Diffraction effects reduce the quality from f/11 onwards.
Lateral CAs (color shadows at harsh contrast transitions) are very well controlled at less at 0.7px on the average pixel at the image borders. This is nothing to worry about in field conditions.
However, the lens can show some purple fringing in extreme situations - this problem is more difficult to correct than "normal" CAs.
The quality of the bokeh (out-of-focus blur) is, of course, a primary aspect of a fast prime lens and the Color Heliar manages to provide very pleasing results here. Out-of-focus highlights show a slight outlining effect at f/2.5. The quality of the blur in the critical focus transition zones is very smooth both in the image foreground and background.
notice below the halos have different colors - magenta (red + blue) in front the focus point and green beyond. This is primarily a problem at f/2.5 and f/4. The issue dissolves from f/5.6 onwards.
Upon closer observation you may also be able to spot a fairly obvious focus shift towards the background when stopping down - this is a quite wide-spread problem on fast lenses.
f/2.5 |
f/4 |
f/5.6 |
